Spider Steering box
Spider Steering box
Does anyone know if any vendors or shops rebuild Spider 2000 steering boxes ??
lanciahf
Re: Spider Steering box
Post by lanciahf »
Dave,
I think Midwest Bayless offers their service. But i think you have to buy a 95 amp alternator first.
124JOE
Post by 124JOE »
are you sure its the ST box
not the idler on the pass side?
Ralph!!!!!!!!!!!!!!!! you are sooosooo funny. LOL
jpaulus53
Your car is a: 1977 fiat spider
Post by jpaulus53 »
I don't know for certain , but i have heard that the Lada steering components will work.
There is a short arm version and a long arm version.
Link to Lada parts
http://www.ebay.com/sch/i.html?_odkw=la ... sacat=6000
Thanks, I heard the Lada box could be modified to work also, some say the internals can be swapped to the Fiat box. I am looking for some one who has done it to get the correct part numbers or a vendor who sells rebuilt steering boxes.
jpaulus53
Post by jpaulus53 »
jpaulus53
Post by jpaulus53 »
also this add notes a parts replacement list for the steering box.
good luck,\.
http://www.fiatplus.com/STEERING-BOX-130.00-CORE.html
ClarkTheShark
Post by ClarkTheShark »
The best solution to your problem is to find a used box, drain it, clean it, replace the seals, fill it with fresh oil, install it and adjust it. itll run like new. made a world of difference in mine. I had 30 degrees and play that I couldn't adjust it any tighter.
I have a few used steering boxes but the play in mine is at the bottom where the pitman arm is. The shafts are worn and pitted where the needle bearings are. Also I haven't been able to find any repair info on the steering box. I would think there is a separate service manual for the steering box.
