81/82 VIN Question
bradartigue
81/82 VIN Question
Post by bradartigue »
Do you have a 1981 or 1982 Spider? I am trying to validate how FIAT stamped the bodies. Does your car have both a 17 digit standard VIN (e.g. ZFAAS00B0C5003121) and a FIAT sequence number or VIN ZFAA124CS0*888888) ?
I am trying to determine what the first and last cars made with the standard VIN were. I know the last car made with the old body sequence was 186979, and presume the first made in 1982 was 5000001. I know the last VIN issued in 1982 was 5003121 (presumably the 3,121 car made in 1982).
The FIAT service letter on the subject is useless.
I think that all of the standardized VIN cars, the ones made after 186979, were assembled entirely at Pininfarina. The VINs for these cars all seem to have a 5 in the assembly position (pininfarina) vs. an 8 (lingotto).
As with all things FIAT in the 80's the real answer is probably lost.
Re: 81/82 VIN Question
the number stamped in my car is ZFA124CSO*08181391
the windshield vin tag is ZFAAS00B8181391
Hope this helps
bradartigue
spider2081 wrote:the number stamped in my car is ZFA124CSO*08181391
Hope this helps
Yes - so this is a 1981, correct? Body 181391, or the 181,391 Spider built.
In 82 they switched numerics. I'm wondering if the 82 has both the ZFA124CS0*xxxxxxxx and the ZFAAS00B8 (or B5).....
aj81spider
Post by aj81spider »
Not sure if I'm adding anything, but here's the numbers on the 1981 I owned:
VIN tag: ZFAAS00B7B8181013
Firewall stamp: ZFA124CS0 * 08181013
A.J.
2006 Corvette
Yes its an 81 but I typed the vin incorrectly should have been: ZFAAS00B6B8181391 Sorry about that.
redcars
Post by redcars »
On my 81 Vin 124cso*00174986 firewall ZEA124CSO*00174986 tag on firewall ZFIAT124CSO*00174
On my 82 Vin ZFAAS00B8C8188523 firewall *ZFA124CSO*081B188523 on tag the first one or two charectors are messed up
what follows is A124CSO*08188523
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
jfrawley
Your car is a: 1982 Spider
Post by jfrawley »
1982
Build date: 11/81
Windshield Tag: ZFAAS00B9C5000674
Body Stamping: ZFA124*CSO*05000674
Hope it helps.
JF
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
bradartigue
jfrawley wrote:1982
Build date: 11/81
Hope it helps.
JF
This is exactly what I needed. Says to me "Fiat (ZFA) Spider (A) Convertible (S), Base (0), Manual Seatbelts (0), 2000cc (B), Check Digit (9), 1982 (C), Plant (5), Body #000674. If the last serialized Spider was 186979 and the first VIN identified Spider was 1 then you add the digits after the 5 to the last serialized number to get your sequence...e.g. your car is #674, which would be body 186979 + 674, or the 187653th Spider body built.
rballart
Post by rballart »
Sorry for the late response but had to register to post. Bought my 1982 Spider new. It was made in March 1982:
VIN ZFAAS00B9C5003123
Engine Bay ZFA124CS0 05003123
3123 seems to be beyond the number you listed.
Ralph B
rdv
Your car is a: 69 AS Spider
Post by rdv »
Hello at all,
from the german fiat spider registry I can tell u that the last numbered fiat spider 2000 is: ZFAAS00B1C5003925!
I found that by testing the calculated later VIN numbers at: http://www.autocheck.com.
Records found for this vehicle: 9.
One later car was found in Hamburg, Germany with ending number: 5004034! But not sure, because not proofed by a picture of the VIN plate behind the windscreen.
Manufacturing of the FIAT Spider 2000 must ended with holidays at the Pininfarina plant in Italy around 06/82.
The manufacturing at FIAT plant ended with VIN: ZFAAS00B9C8189261, which must be around 10/81.
Hope that helps.
Greetz
Ralf (Registry admin)
PS: Any new spider for the worldwide spider registry is welcome at:
https://www.fiatspider.de/de/interaktiv ... ister.html
To register a new car:
https://www.fiatspider.de/de/interaktiv ... ntrag.html
PPS: Sorry for the only german page!
69 AS Spider
the Worldwide Spider Register
bradartigue
It does and think you. This stuff is very interesting to me.
Does anyone know the last pininfarina VIN # ever produced? Wondering if it is 5010018.
rdv
Post by rdv »
Hi,
as last proofed Pininfarina Spider we found:
VIN: ZFRAS00B8F5511939.
"Last known VIN of a Fiat 124 Spider found via http://www.autocheck.com. Records found for this vehicle: 7"
Here at fiatspider.com VIN ..11940 was reported as:
"The last spider is 5511940 according to Pininfarina not what is on people's web sites."
Ciao,
Ralf (Admin Spider Registry)
69 AS Spider
bradartigue
The VINs on Autocheck.com are not all real VINs. They put a bunch of stuff on the search pages to attract hits to their website. I've found it to be very unreliable.
I'm a bit confused though, you're saying someone registered ZFRAS00B8F5511940 on your website?
rdv
Post by rdv »
Hi again,
here in the forum wrote Darsella1 in 2010:
The last spider is 5511940 according to Pininfarina not what is on people's web sites. I have VIN# as high as 5511936 & 5511935, both were for sale in Colorado several years ago. The last few are actually in the USA as Micheal Blumberg purchased them at 5-6 at a time and imported them here.
So, this is my source!
Bye,
Ralf
69 AS Spider
