Hi gang. Well, for those of you who don't visit Mirafiori, here's how I got the Fiat home:
The car did absolutely great the first day. Mom and I were really having a smooth ride. On the second day we hooked up with a group in central Ca. and headed up Hwy 1. Bad mistake for me. My car started overheating any time I went up a grade. At first I thought it was a blown head gasket, but it was fine when we pulled the head off. Turns out it was a leaky gasket at the mounting plate on the tube coming back to the water pump from the heater core. That's the suction side so it was pulling in air and displacing coolant. We got that fixed but after I drove it from the shop to the motel it won't start. I was stuck in Grant's Pass, Oregon for two days getting it worked on the way up to Washington to drop off Mom after the campout. The tow car is Mom's, and she's been trying to sell it so I used it to tow my car home and I'll list the Mountaineer here in So Cal. Now I have the Fiat in the garage and I am going to have to figure out why it's not getting power to the fuel pump and fuel injectors. The fuel pump runs if I take a hot wire to it, so it's good. The dual relay and ignition switch were just replaced, and the in-line fuse is good, so at this point I'm suspecting the ECU. I'll have to find one that works to swap out and hopefully that will get it running again. Mike Mudge suggested I put a resistor in the connector for the temp. sensor in the "T", but that didn't do it either.
Towing the trailer didn't wasn't what caused the problem, a PO had cut off the bracket that supports the heater tube so it was able to move and eventually caused the leak.
The two injector ground wires are in place and snug, so that's not it.
Any suggestions would be gratefully accepted.
Meanwhile, I won't be getting a lot of rest until I get this figured out.
(I still am partial to the '82's)
