Seat foam and wire frame
saidja
Your car is a: 1978 sportspider 1800 CS1
Post by saidja »
Just bought new foam for my seats.
They are slightly different although a bought them as BS/CS models.
The wire frame is not fitting so nicely the new foam. And this seems the only way to connect the foam to the metal structure.
Any thought on how to handle this? Or any similar experiences
PaulC
Patron 2022
Patron 2022
Re: Seat foam and wire frame
Post by PaulC »
Looks about right for the new foam. The older stuff has probably lost its shape over the years.
You fasten the foam to the frame with hog rings. There should be wires on the top that run in the longitudinal channel in the foam. The hog rings go around these wires and the underside wire frame. You can use wire coat hanger wire for the upper wires.
saidja
Post by saidja »
thanks!
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
Where did you purchase the new foam?
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
I noted the same issue when I replaced my seat bottom. I ended up trimming the new foam for length and shape at the back. Plus also trimming the bottom so the wire would fit
It worked even though I didn’t put the top wire bit and springs in. Mine didn’t have them
Cheers
Dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
Where can you buy foam for the seats?
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
tima01864 wrote:Where can you buy foam for the seats?
https://www.vickauto.com/newstore/index ... cqh39r0m43
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
