Hood Removal
4uall
Hood Removal
Post by 4uall »
Once again I searched and am at a loss :evil: Does anyone have instructions (photos are always a big help) on how to remove the hood?
As always, thank you in advance
PS I love this forum :D
azruss
Re: Hood Removal
Post by azruss »
this is an exercise fraught with peril. having an extra person or 2 is a must. the hood is held on by each hinge with 2 bolts each. remove the spring or the sliding rod first. once this is disconnected, the hood is free to swing forward until something you dont want to happen happens, so one person's job it to keep this from happening. best to loosen all 4 bolts until they are almost ready to fall out. while holding the hood on both sides in a near vertical position, remove the 4 bolts and lift the hood away. If you dont have any help, you can open the hood and clamp the top to a vertical 2x4. this will help hold the hood, but it is still very unstable and easy to lose control. good luck, you will need it :roll:
4uall
Re: Hood Removal
Post by 4uall »
Thanks so much for the quick reply. Sadly, I am still at work :cry:
narfire
Re: Hood Removal
Post by narfire »
I'll second the two person removal. It is not heavy so the better half can help if required. VERY easy to prang the paint on both the hood and fenders when removing . I take a thin felt pen and mark the hinges to the inner fender before removing. That helps in alignment when putting the thing back on (again two people)
Chris
Re: Hood Removal
I remove the hood alone in a garage. I screwed an eye bolt into the ceiling joist above the hood. Open the hood tie a close line like rope to the hood latch on the hood then pass the rope through the eyelet and tie it off. Next remove the bolt that holds the round plastic disk in the center of the hood torsion spring. Roll the car so the hood points straight up and re-tie the hood in this position. Now remove the 4 bolts that hold the hood to the fenders. Push the car back away from the hood. Lower the hood slowly with the rope.
burgandy81
Your car is a: 1981 FIAT Spider 2000
Re: Hood Removal
Post by burgandy81 »
I just did this for the winters projects.
As above, 2 people are best.
I used green painters tape on the body near the hinges. Painters tape first to protect the paint and then duct tape to stop the hood from tearing the painters tape.
Saved me a few extra scratches.
Jordan
PS it is reasonably light. I am storing mine on the convertible roof.
johndemar
Your car is a: 1976 Fiat 124 Spider
Re: Hood Removal
Post by johndemar »
Before removing the bolts I always outline the hinge with a non permanent marker. Makes lining it up to reinstall easier.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
azruss
Re: Hood Removal
Post by azruss »
pre marking your hinge location is a great idea. I drill two 3/16" holes in each hinge while mounted and aligned. when you put the hinge back on, put a couple of 3/16" drill bits in each hole and you dont have to mess with realignment. I do the same thing with door hinges.
